set clock 2003 cavalier
I'd like to know that as well. And don't fret over the manual. In my configuration at least, the button which the manual instructs to press and hold to set the clock is located about an inch bellow the the volume **** which sits about a half inch above the plastic rim surrounding the radio, making the button rather hard to press.
I can’t see your buttons but if you have a “set” button then typically you click that and then press either “Seek” or “Scan” for the different directions for the clock. After you set the hour then click “set” again and do the minutes.
