Platform: J-body
starting problem
Old May 19, 2009 | 6:44 PM
ahimsaman72's Avatar
Question starting problem
have 95 cavalier, standard engine.
turn ignition switch, hear grinding and flywheel spin. it takes a while of turning ignition for the engine to "hit" and start running. a friend said it was the solenoid not giving enough power. haven't taken it off yet to have it tested.
solenoid and starter are on bottom of engine. use a floor jack?
Any feedback would be appreciated.
Thank you!
Old May 19, 2009 | 6:50 PM
suzuki-guy's Avatar
First off welcome to the forum!!!
Now your problem is your starter! Im not sure if the solenoid is seperate from the starter or if it is all one unit! But the starter should be on the passenger side of the engine block on the bottom! Can anyone verify this?
Old May 19, 2009 | 7:47 PM
Mike Sigmond's Avatar
ROTM Coordinator
Default removal procedure for starter on 2.3l & 2.4l
  1. Disconnect the negative battery cable at the battery.
  2. Raise and safely support the vehicle.
  3. Remove the electrical connections from the back of the starter.
  4. Remove the bell-housing cover.
  5. Remove the starter support bracket bolt from the engine block.
  6. Unfasten the starter motor-to-engine bolts, then carefully lower the starter.
  7. Remove the nuts/bolts that hold the starter support bracket to the starter.
Your right Suzuki-Guy, its on the passenger side.
And welcome to the forum!!
Old May 19, 2009 | 8:36 PM
suzuki-guy's Avatar
Thats what i thought. If it was a truck I would be positive, but I have never owned a car. Ive owned six trucks though! All chevys of course! Good luck Ahimsaman!
If you get a second stop by the Ride of the month and vote for this months winner! Simply click on the link in my signature!
Old May 21, 2009 | 1:01 PM
Thanks Suzuki!
Advance Auto sells them as a package deal. I found the starter in the front near the bottom. Seems pretty easy.
Thanks again.
Woody
Old May 21, 2009 | 1:04 PM
Thanks alot my friend for the info!
I found the starter in the front middle of the car. I traced the positive cable from the battery and it was easy to find once I looked good enough. Maybe my model is weird or something. It's a 2.2 regular motor.
Again, thanks alot for the info. I'm changing it out tomorrow when I get paid!
Old May 21, 2009 | 1:06 PM
Thanks Suzuki.
I may need all the luck and skill I can get. I've owned this car for a couple of years. Bought it and it only had 35k miles on it and it is 14 years old. I'm thinking since it wasn't used much there are some corroded parts that weren't put under much load. I commute with it every day.
Old May 21, 2009 | 3:02 PM
ROTM Coordinator
Glad we could help!
amesblog
Sep 14, 2014 4:31 AM
TG
Aug 16, 2006 4:30 AM
ffarv
Apr 9, 2006 1:52 PM
