Platform: J-body
Steering Wheel ground / No horn problem
Old Sep 4, 2010 | 3:22 PM
wmentzer's Avatar
Default Steering Wheel ground / No horn problem
I just replace the turn signal / 4 way / headlight switch, thinking that the pin that contacts the horn slip ring behind the steering wheel was bad. Now I find out that I have an problem ground.
Where does the steering column get its ground? I have tried a grounded jumper all the way from the horn button to the passenger compartment side of the steering column univeral joint and the horn works. If I push the horn button, this same steering column has 12 volts on it, like it's insulated, but it should be grounded for the relay to work. What am I missing?
Is there a braided grounding strap that goes around the universal joints for grounding purposes?
vynilmikings
Sep 5, 2010 11:51 PM
JWood83
Feb 16, 2010 12:17 PM
bullet62
Nov 26, 2009 11:09 AM
isaac_22
Dec 26, 2007 9:23 PM
zulu
Mar 28, 2007 4:58 AM
