Platform: J-body
Stereo Wiring
Old Aug 13, 2007 | 8:48 AM
01chevycavz24's Avatar
Default Stereo Wiring
I have a 2001 Cavalier and I am putting a system in and i want to keep the factory cd player in. I got the box to hook up to the factory wiring for the RCA's i just need to no if anyone can help me on what wires are what?
Old Aug 19, 2007 | 1:46 AM
02blue1's Avatar
Default RE: Stereo Wiring
you'll need a voltmeter to find your power wires. there's gonna be a 12v constant, 12v switched with your ignition, illumination that works off your headlights. Once you determine those wires mark them as power wires. then, get yourself a 9v battery with leads off the positive and negative and start touching terminal ends inside the harness. DO NOT TOUCH THE POWER WIRES! when you complete a circuit to a speaker you'll hear a pop in the speaker thus determining what speaker you have. No, it will not harm the speaker. Correct polarity you will see the speaker move outward ( if you can see the speakers) and negative polarity the speaker will move inward. Make sure you're factory is not amped. If it is don't use the 9v method. Easiest way is to find some old broken device that uses a 9v and cut the wire harness to get your leads off of the 9v. The only other easy way would be to get a direct connect wire harness from an install shop that has the wires marked. you just plug it in and re-solder. Hope this helps!
Old Aug 30, 2007 | 11:14 PM
renojoe87's Avatar
go to installdoctor.com has all wire codes for your car makes life real easy.
tranceport185
Aug 19, 2023 11:04 AM
davet
Feb 17, 2022 8:08 PM
heybuddysweetbowtie
Nov 5, 2021 5:42 PM
shayneneal
Aug 27, 2009 5:52 PM
UlexiteCavalier
Feb 16, 2009 8:56 AM
