Last edit by: IB Advertising
Browse all: Powertrain Guides
- Chevrolet Silverado 2007-2013: How to Replace Idler and Tensioner Pulley
Tensioner pulley won't budge
Hello, all. I am glad I found your forum and I appreciate you all letting me join up.
I am replacing the alternator on my 2002 Cavalier. I cannot get the tensioner pulley to budge. BUT, dang it, I forgot to loosen the tensioner pulley BEFORE I took out the 3 bolts on the alternator
. Now I cannot get the pulley to budge so that I can get the serpentine belt off. Is it because of the tension of the belt on the alternator now that the alternator is askew? Or are these pulleys always very hard to move? (I'm an old battle-axe and I have tendonitis in my right thumb so maybe I just cannot get enough umph into it...?)
Thanks very much...
Carolyn
. Now I cannot get the pulley to budge so that I can get the serpentine belt off. Is it because of the tension of the belt on the alternator now that the alternator is askew? Or are these pulleys always very hard to move? (I'm an old battle-axe and I have tendonitis in my right thumb so maybe I just cannot get enough umph into it...?) Thanks very much...
Carolyn
I take it you loosened the alternator bolts before removing the serpentine belt? I am not sure what socket size to put on that tensoner, but with that and a break over bar, with the correct size socket on the tensoner pulley rotate it against the drive direction, and remove the belt. Then replace the alternator, reinstall belt according to the pulley diagram.
yes, EXACTLY what I did! In my defense, I was distracted by an idiot feline who kept jumping up into the engine, LOL!
I'll try with a socket and breaker bar rather than the wrench...bit more leverage, you're right...thank you!
One thing after you replace the alternator, and inspect the belt before reinstalling it, is with it running make sure the belt rides "straight" with the system. The tensioner if worn out might make the belt ride off sideded, that will cause a problem. I replaced mine in my Lumina after replacing a worn belt since it wasn't tracking true to the pulley system.
I have 5 cats.
I have 5 cats.
then you understand my feline dilemma, ha ha!
TY for the tips re the belt - i WILL check that for sure to make sure it's fitted correctly.
so you mean to move the pulley itself rather than the bolt...i hadn't thought of that!
i tried a socket and there's not enough room to fit it in there...just too tight. i tried with the wrench again and got it to budge a little but not enough. of course, i didn't have a piece of pipe around that would fit over the socket handle so i could get some leverage that way. SO, gonna round up a piece of pipe today...or weasel a guy friend into doing the guy thing...but i hate to have to do that... or maybe see if i can round up something to pry with. i like to dink around with cars, actually. but it can be so aggravating when you're trying to get on the road and the going is slow.
The replacement ones have that, original equipment on an 02, not sure, but don't think the 3/8 cutout for a breaker bar is there.
