Platform: J-body
whirring noise while driving straight
Old Jul 5, 2010 | 3:39 PM
Ruinousmanual's Avatar
Default whirring noise while driving straight
2002 manual cavalier makes a whirring noise while driving and keeping the steering wheel straight. When turned left or right the noise stops, however it takes more turning to the left to stop the noise then when turning the wheel to the right. I do not know what this is.....the tires do not wobble while up on the jack tie rods are good brakes could be changed but not bad. The tires are good but have had problems in the past with ball bearings. Anyone have any ideas on what it could be? The noise is coming what seems to be either from the front center or the front left.
Old Jul 11, 2010 | 2:56 AM
jgourley5315's Avatar
I would check the wheel bearings first if not that then try the cv shafts... sometimes you can put it on jackstands and rotate the tires while your under the vehicle to pinpoint where the noise is coming from. Let us know how it turns out!
Old Jul 15, 2010 | 1:39 PM
So it wasthe bearings......that i had just had replaced 8 months prior. I must have gotten a bad bearig....on top of that the rotors also needed to be replaced.
bass2112
Sep 21, 2012 10:43 AM
davtak
Jun 27, 2009 5:28 PM
MiggzHoe
Oct 28, 2008 10:46 AM
gulfcoastjoe
Jun 19, 2007 10:23 PM
ketedford
Aug 29, 2006 5:31 PM
