Central MT, WY, CO, ND, SD, NE, KS
Making me dumb founded
Old Jul 23, 2020 | 12:00 PM
Dale Wilcox's Avatar
Default Making me dumb founded
I have a 2001 S10 extended cab 4x4. I recently started having problems getting my pickup started. I put in a new battery, and starter but still having the problem.
Ok...when I turn on the key trying to start the pick up it just make a clicking (this happened the first time) sound. That's why I put in a new battery. Troubleshooted more and decided I need a new starter as I was thing that the solenoid was the problem. That was the reason for putting a new starter in it. I decided to charge the battery.
All right. After all of the above I go to start it and I get on clicking sound and I loose all power. I could really use some help.
Dale
Old Jul 23, 2020 | 1:12 PM
kevinkpk's Avatar
Dale
Check your connections, especially battery. Have you tried jumping the starter solenoid?
Old Jul 23, 2020 | 2:05 PM
Check your battery cables at both ends as well as the connections. Also check the ground strap to the engine block.
Old Jul 24, 2020 | 11:27 AM
I did and was able to start the pickup.
Old Aug 14, 2021 | 1:45 AM
Renald Septian's Avatar
I would suggest you look at this license plate lookup, via VinPit here. I have many experiences in purchasing and selling used cars. This tool helps a lot for me to look at the history of an old car that is beneficial for purchasing.
countrigrl878787
Jun 27, 2015 12:11 AM
tapout95
May 30, 2015 1:16 PM
lc1025
Jun 7, 2012 12:07 PM
