1969 el camino brakes
Old Jul 2, 2017 | 10:47 AM
zapparex's Avatar
Default 1969 el camino brakes
adding power brake booster to manual brake 1969 el camino
Old Jul 2, 2017 | 10:55 AM
zapparex's Avatar
Will I have to change brake lines and add a new master cylinder
Old Mar 23, 2020 | 3:48 PM
Am4wag's Avatar
Yes,and also proportioning valve.
Old Mar 23, 2020 | 9:33 PM
Rednucleus's Avatar
Going from drums to discs as well??
Old Mar 24, 2020 | 9:04 AM
Am4wag's Avatar
Yes.There are different proportioning valves for different brake configurations.You gotta start changing lines when you encounter different (after market) proportioning valves.Give you an example:My 69 El Camino didn't have a booster on it,but had disc up front.Was a bear to stop.I believe the m/c was either for power brakes or manual drums,probably a different bore as well.I got a booster and m/c kit from Right Stuff detailing (see below).The proportioning valve is located from a bracket coming off of the m/c now.Originally the valve was below firewall on drivers side.Keep in mind that the original lines going in and out of the p/v have different sized fittings,and that rear lines are 1/4",front lines are 3/16". https://www.summitracing.com/parts/rsd-g81310971
Gunnar
Chevelle & El Camino
Apr 7, 2019 5:43 PM
tomthecarguy
Jul 16, 2017 1:59 PM
elcaMEANo
Jan 22, 2017 9:32 PM
chevellenut
Jun 19, 2014 10:42 PM
cwr68
Nov 12, 2006 12:37 PM
