1951 Chevy 3100 Fuel System
Old Dec 11, 2025 | 9:53 PM
MishaZ's Avatar
Default 1951 Chevy 3100 Fuel System
I decided to update the fuel system on my 1951 Chevy 3100. I replaced the tank, sending unit, fuel pump, lines and filter. Issue I'm not having is that no fuel is pumping to the carburetor.
I disconnected the line ahead of pump and there is fuel there. Just incase I got a bad pump, just installed another pump and still have same issue. I attached a rubber hose to the pump inlet from a bowl of fuel, and still nothing. I'm going crazy, what can be the issue? Does vacuum advance play any role in this? I also replaced it.
I primed the carburetor and engine will start after some trying and will run for a bit, but stops as no additional fuel is coming.
Old Dec 12, 2025 | 8:24 AM
Welcome from Florida. Was the fuel pump you replaced working? If it was, put it back in to see if that solves the problem. I have the same problem with a 1949 Fleetline. I tried several new fuel pumps without success. I finally put an electric fuel pump in it outside the tank. and now it runs.
Old Dec 16, 2025 | 8:16 PM
Charles J Edward's Avatar
Default Maybe try this ?
Try hooking a hose from the outlet of the pump and running it into a bowl of fuel and trying again.
87chevyman
Feb 13, 2024 2:09 PM
O'Boyd
Jun 26, 2022 8:58 AM
XAQSHNR
K5 Blazer
Mar 29, 2020 5:16 PM
tom5170
May 9, 2010 6:55 PM
Khazlett
Jan 19, 2010 1:29 PM
