84' Silverado - turn lever not returning
Old Oct 7, 2017 | 10:51 PM
Bruce Gordon's Avatar
Default 84' Silverado - turn lever not returning
Hi,
My truck arrived with a fault I'd like to fix. If you use the turn lever to the right, the lever will return to centre after making the turn.
But if you use the turn lever to turn to the left, it does not return, and the turn indicators remain on.
I assume there is some kind of switch inside the cover on the steeting column, can anyone point me to the part, as I don't fancy importing a whole column to New Zealand just for a part that could be posted in a small bag.
Appreciate any help.
Bruiser
Old Nov 13, 2017 | 9:16 AM
jbsealy's Avatar
Notice this is a month ago, but if not yet resolved........... there are right and left springs which return the signal lever. To access you must remove the steering wheel to access the turn signal mechanism. Not difficult, but this requires TWO special tools. I recommend you search YouTube for a video.
Cheers JS
Old Nov 13, 2017 | 12:37 PM
bandit_601948's Avatar
the switch under the steering wheel is bad ! just ask the parts store for a turn signal switch !
Old Nov 13, 2017 | 2:20 PM
jbsealy's Avatar
Bandit,
Yo Bandit,
You evidently have never installed the part. Replacing the turn signal switch is not hard, but a pain in the *** and fairly involved. For one side not cancelling, probably just need a little spring and not the whole part.. Regardless It requires two special tools. Both tools can be rented at most parts stores. YouTube video to replace spring:
Replacing spring:
J
Old Nov 13, 2017 | 3:10 PM
kevinkpk's Avatar
The springs are in the switch, and I'd HIGHLY recommend replacing the entire assy. The small "strap" on the right of the image is the switch. You just need as far as special tool, steering wheel puller. The biggest "pain" is the electrical connector running it down the column. Opps, you will need the spring compressor tool, that screws onto the shaft.
Last edited by kevinkpk; Nov 13, 2017 at 3:11 PM. Reason: Opps, you will need the spring compressor tool, that screws onto the shaft.
