85 cab on a 77 frame
Old Feb 26, 2022 | 2:11 PM
straubman's Avatar
Question 85 cab on a 77 frame
ok, Hello to all. I am building an 85 squarebody truck but the frame i have is a 77. My question is which body mounts do I need? I have heard they are frame specific not body specific, but the height differences are quite a bit. is the difference in the location of the body mount brackets on the frame? The 73-80 ones are much taller than the newer ones in the back for sure. The one place I was reading said you can use either one as long as you change all of them and the hardware, the only problem I see with this is the holes in the older frame are too small for the newer body mounts to fit in. I can drill bigger holes in them if they will work. Any help is appreciated.
Deathek
Sep 7, 2011 8:55 PM
Jmar595
Sep 17, 2010 5:32 AM
Craig D
Aug 16, 2010 5:17 AM
GFunkk
Aug 7, 2009 11:33 AM
mombofan1
Oct 26, 2007 11:32 PM
