!971 C20 Ignition switch bezel
Old Apr 9, 2018 | 2:57 PM
kevinkpk's Avatar
Default !971 C20 Ignition switch bezel
I am needing one of these, number on it is 3918892. Previous owner tried to replaced the switch (I guess) without knowing the locking cylinder has to come out, this ones threads are stripped.
Old Apr 15, 2018 | 5:58 PM
kevinkpk's Avatar
Ok, got this problem solved. On the C20 1971 does the door locks use the same key as the ignition? I am needing to replace the switch, but unsure if the same key (on this model) is also for the door locks.
Old Apr 16, 2018 | 5:14 PM
kevinkpk's Avatar
Got this figured, now, and I think I know the answer to my question. 1971 C20, is the door lock key same as the glove box, and not ignition?
