Fuel Pressure Test - 1980 K10
Old Sep 5, 2022 | 9:51 PM
RiderOfShelob's Avatar
Question Fuel Pressure Test - 1980 K10
I need to run a fuel pressure test, and I am trying to find the optimal place to tie in my pressure gauge. I know a lot of Chevys have a removable cap just for that purpose, and I am able to find information for the location of those caps on later models, but I can't find anything for a 1980 K10 5.7L 8 Cylinder 350 engine. I could always tap into the line before the fuel filter, but if there is a designated location for the gauge to connect, I would rather use that and do it right. If anyone could tell me the location of the tie in point, or other ways of testing the pressure on that model, I would greatly appreciate the help. Thanks!
Old Sep 5, 2022 | 10:03 PM
oilcanhenry's Avatar
What carburetor are you running?
Old Sep 5, 2022 | 10:11 PM
It's an Edelbrok 1406
Old Sep 5, 2022 | 10:35 PM
You only need 6.5 PSI for your Edelbrock 1406.
Old Sep 5, 2022 | 11:01 PM
You will need to check your fuel pressure at the carb inlet with a double hosed fuel pressure gauge. You run one hose to the carb and the other to the fuel hose from the fuel pump.
Old Sep 5, 2022 | 11:04 PM
Thank you, I’ll give that a shot!
lkaras99
Sep 15, 2020 3:16 PM
Uncle_Charlie
Mar 29, 2014 4:51 PM
mattysgarage
Mar 23, 2012 4:00 PM
88 4X4Dumpster
Oct 19, 2010 6:18 PM
carlsndfw
Jan 8, 2007 5:10 PM
