Need help locating a power steering pump single groove pulley.
Old Feb 25, 2018 | 11:37 PM
Kazoocruiser's Avatar
From: Currently the Candian Gander is wintering over in New York.
Default Need help locating a power steering pump single groove pulley.
Hi, new member here with a problem. I broke the power steering pulley hub while trying to remove the pulley. I'd rather not reuse the pulley. The truck is a 1981 C10 with an inline 6 (250/4.1). The Dorman part (300122) offsets the pulley inboard about 1/2" and cannot be used because of belt misalignment. It is supposed to be for a 1982 and later. My pulley has a number: 14025192 and has a concave face on the front. The Dorman unit looks like it is welded backwards on the mounting shaft. Whatever web and Ebay searches I have done show the part no longer available from GM. Help help help!
Old Feb 26, 2018 | 7:16 AM
oilcanhenry's Avatar
I'd call the wrecking yards. Most have a system for
looking for old parts.
Old Feb 26, 2018 | 7:47 AM
If you can't find it at the junk yard you can always use the Dorman pulley with a 1/2" spacer to move it back out to where it is supposed to be.
Old Feb 26, 2018 | 4:30 PM
Thread closed. I found a used pump with the pulley on it today at a salvage yard.
