Cobalt This sporty compact was faced with the difficult job of replacing the popular Cavalier, but whether the base model, or the supercharged SS is chosen, is has made for a great replacement.
Platform: Delta
Also Check out CobaltSS.net
06-09 2.2l Complete Swap issues
Old Oct 27, 2021 | 7:37 AM
ZRJO's Avatar
Default 06-09 2.2l Complete Swap issues
Good morning everyone,
I have a issue with an engine swap and wiring swap I've done to my 06 cobalt. I had a do ar car which was a 2009 chevy cobalt and took every module (tcm, ecm, bcm, tdm, cluster, radio, radio receiver) and the entire car's wiring harness and I plugged every module and nothing happened. The engine didn't turn over, starter didn't activate, fuel pump didn't prime and also getting a low fuel light message with the guage saying my tank is empty even though there's half a tank of gas in my car. The car had an airbag deployed but I would assume the srs system would not effect the engine not cranking.
After that didn't work I went to a junk yard and got everything except the wiring harness from a 2009 pontiac g5 and had the same issue but now I don't have a check engine light. I swapped ecms and still no cel, then checked the fuse for the fuel pump and no voltage at all. And the relay gets voltage but only 10v when the key is in the on position. I'm really confused what I did wrong, I would expect it to be plug and play since I literally have every module and all the wiring.
I would like to add that I did check pins 6 and 14 on the obd2 port and I get 120ohms. The wiring in my car now is from the 2009 chevy cobalt.
Anything would help and thank you for even replying to my message.
Sincerely,
ZRJO
ZRJO
Cobalt
Sep 28, 2021 7:12 PM
bsean63
Cobalt
Apr 24, 2019 6:04 PM
dahmadon
Cobalt
Dec 9, 2014 10:48 PM
weeks85
Sep 5, 2010 4:58 PM
GLH
Sonic (Aveo)
Aug 27, 2009 9:30 PM
