Cobalt This sporty compact was faced with the difficult job of replacing the popular Cavalier, but whether the base model, or the supercharged SS is chosen, is has made for a great replacement.
Platform: Delta
Also Check out CobaltSS.net
06 cobalt p1810 Transmission Fluid Pressure Switch problem
Old Apr 10, 2013 | 2:34 PM
jesseRI's Avatar
Default 06 cobalt p1810 Transmission Fluid Pressure Switch problem
I had a P1810 code show up, (P1810 Transmission Fluid Pressure (TFP) Position Switch Circuit TCM)
I read a little about it, and I don't know much about cars, so I hope to get some info before having a mechanic tell me something beyond the real problem.
I noticed a harder shifting occasionally (but I read about this online). curious though, would this problem be associated along with this issue i'm having. when I press the break, the lock disengages in the automatic shifter to allow it to move out of park. Normally in drive, when you press the brake, there is no clicking/disengaging sound coming from the shifter. but after driving a bit, i start to hear the click every time i press the brake... this is when I know that the car will shift into the first 2 gears very firm.
are these 2 things associated?
I brought it to a chain transmission shop, which I shouldn't of... it took them 4 days to get back to me with any answer. they don't seem trustworthy and neither do their yelp reviews. He said he thinks it is the transmission pressure circuit board, which is located inside the transmission and will cost 600$ for them to open it up and look at it.
on my car is this true that it is located inside the transmission and will require a good amount of $ to replace?
2006 Chevy Cobalt LS 2.2
Thanks so much for any help!
Jesse
Old Apr 10, 2013 | 2:49 PM
kevinkpk's Avatar
What I read in my Haynes manual (not an atuo tranny man)is that codes says pressure switch assymbly malfunction. I say that it is broken, hence the code, and hard to shift into gear. Either way you will have to drop the pan.
Old Apr 16, 2013 | 1:06 PM
jessetheaviator's Avatar
so an update, to see if this stuff sounds right....
AAMCO said it was going to be 600$ to open up the transmission, change out the pressure switch and see what other damage is done.
I brought it to another respectable company, 4.5 stars on yelp, etcetc. he seems honest.. says.. the shift solenoid clicking could be a separate issue than with the transmission banging into 2nd gear and giving little power output at times. however, step 1 is to replace that pressure manifold sensor. he said its 162$ in parts for the sensor, fluid and gasket. but its 7.5 hours of labor for 715 for a total of 950ish$.
he said he worked at aamco a long time ago, and they quote you a lower amount, then say you need to repair the whole transmission or get a new one leading to lots more$$$$.
he said something about dropping the chassis. but i have no idea if this is normal.
thoughts ?
thanks.
Old Oct 10, 2013 | 7:33 AM
andrewk's Avatar
Default Fix?
Did you ever fix this? My 2010 cobalt is doing the same thing. Shifter release clicking when driving and pressing the break pedal.. and then shifting hard...
Old Jun 22, 2014 | 4:30 PM
Bjspence's Avatar
Default Please help P1910 and P0700
[same deal on my 2010 cobalt. Please help
QUOTE=andrewk;258678]Did you ever fix this? My 2010 cobalt is doing the same thing. Shifter release clicking when driving and pressing the break pedal.. and then shifting hard...[/QUOTE]
Old Jun 24, 2014 | 8:53 AM
Official GM Rep
Hi Bjspence,
I am sorry to hear you are experiencing this issue with your vehicle! Our department is unable to provide technical advice; however, we would be happy to get you in contact with your local dealership for assistance. You are welcome to send us a private message at any time.
Jessica
Chevrolet Customer Care
Old Oct 19, 2019 | 7:28 PM
lynnx's Avatar
Default samie issue here
My 2007 chevy is doing the same thing got the same code and the cruse control and break making the clicking sound while the tranny shifts hard they all stop or work fine when it doesnt shift hard. Id have to say they all go hand in hand.
Coravir
Oct 26, 2019 3:28 PM
JessyGirL
Sep 10, 2011 7:07 AM
DeHartShadow
Mar 28, 2010 10:10 PM
junklady
Oct 28, 2009 6:01 PM
