Cobalt This sporty compact was faced with the difficult job of replacing the popular Cavalier, but whether the base model, or the supercharged SS is chosen, is has made for a great replacement.
Platform: Delta
Also Check out CobaltSS.net
2006 cobalt won't start, no recognizable problem
Old Nov 11, 2013 | 11:14 PM
mistyweiss's Avatar
Default 2006 cobalt won't start, no recognizable problem
My 2006 cobalt won't start. It turns over, the fuel pump is working, there is spark. The ignition coil is fine. A mechanic spent 2 hours on it and couldn't find any cause. The check engine light is on, and was on the day before it stopped working, but not the day of. The check gas cap message had also been displayed twice in the days leading up to it. We are out of ideas, as is our mechanic. Any suggestions of what could be causing the problem are welcomed. Thanks!
Old Nov 12, 2013 | 2:21 PM
Do a fuel pressure check. Having fuel is not enough. You need the correct fuel pressure.
Old Nov 12, 2013 | 8:54 PM
Tech's Avatar
Also check injectors for pulsing. Might have theft deterrent problem keeping car from enabling fuel injector for start.
Old Nov 12, 2013 | 10:16 PM
mistyweiss's Avatar
the fuel pressure is fine, we checked it. We also checked the injectors with a stethoscope
Old Nov 13, 2013 | 10:51 AM
Maybe a compression check is in order? a valve not seating could be not allowing the start... just a thought...
Old Nov 13, 2013 | 7:55 PM
+1 for compression check
if your fuel pressure was good, what was the pressure reading? you checked spark with a proper spark tester?
attycda
Dec 27, 2021 12:34 PM
Wstkth
Cobalt
Jan 4, 2015 2:17 PM
dand1966
Uplander
Aug 31, 2009 3:54 PM
bracca
Jul 12, 2009 6:14 PM
