Cobalt This sporty compact was faced with the difficult job of replacing the popular Cavalier, but whether the base model, or the supercharged SS is chosen, is has made for a great replacement.
Platform: Delta
Also Check out CobaltSS.net
2008 Cobalt starting problem
Old Feb 17, 2020 | 10:37 AM
kota1franco's Avatar
Default 2008 Cobalt starting problem
I have a 2008 Cobalt that won't start. When the key is in the ACC position, everything works power wise. When the key is turned to the ignition position, all the accessories go off and nothing happens with the engine.
I have replaced the battery, 50 amp fuse next to the battery, and the crank/start relay. The starter will work when it is jumped with a screw driver.
Any help would be greatly appreciated!
Old Feb 17, 2020 | 1:50 PM
oilcanhenry's Avatar
I have replaced the battery, 50 amp fuse next to the battery, and the crank/start relay. The starter will work when it is jumped with a screw driver.Any help would be greatly appreciated!
The starter solenoid is probably going south or gone, IMO.
Shuwei
Nov 7, 2019 4:34 PM
Cobalt owner
Cobalt
Oct 5, 2019 5:00 PM
Ericgethmann
Cobalt
Oct 7, 2017 4:15 PM
megakick5614
Cobalt
Mar 22, 2015 10:55 AM
2008cobalt
Cobalt
Dec 21, 2013 9:37 PM
