2009 Chevy Cobalt LS 2.2L
Hello, I am Haley.
I have a 2009 Chevy Cobalt, recently I went to leave work and the car stalled twice and would not re-fire.
Trying to start the car, it intermittently primes the fuel pump, starts then stalls out. When it dies the screen reads Low fuel, power steering.
Cluster will spike up sometimes like it wants to start but wont, then a few more cycles of the key the fuel pump kicks on and cluster reads, then car fires up for a few seconds and then dies.
I have changed the Mass air flow sensor, ignition starter switch and swapped fuel pump relay with my A/C relay and still nothing. Also put a fuel pressure gauge on and read 42psi not running, then steady 60psi when I could get the car to fire.
Hello, I am Haley.
Hot wired the fuel pump, it does run. Also I do not believe a bad fuel pump would cause the cluster to sporadically come on and off. The intermittent issue seems like an electrical issue. But thank you!
Of course. Since I cannot see or test your Chevy, the best I can do is give you possible issues that might occur.
51StylelineDeluxe
August 30th, 2012 9:14 AM
