Cobalt This sporty compact was faced with the difficult job of replacing the popular Cavalier, but whether the base model, or the supercharged SS is chosen, is has made for a great replacement.
Platform: Delta
Also Check out CobaltSS.net
2016 chevy cruze won't start after I fill the gas tank.
Old Sep 28, 2017 | 10:10 PM
joethebee's Avatar
Newly Registered
Default 2016 chevy cruze won't start after I fill the gas tank.
my 2016 chevy cruze won't start after i fill it up with gas, thought it was the gas cap but it still doesn't want to start
Old Sep 29, 2017 | 9:07 AM
a stuck open purge solenoid can cause this condition. an evap leak or purge solenoid dtc is an indication of this problem. find the purge solenoid; with the engine off, key off, remove the purge hose, see if you can blow through the solenoid...if you can, replace it.
