Cobalt This sporty compact was faced with the difficult job of replacing the popular Cavalier, but whether the base model, or the supercharged SS is chosen, is has made for a great replacement.
Platform: Delta
Also Check out CobaltSS.net
Aftermarket system question
Old Oct 6, 2009 | 3:46 AM
IndyUchiha's Avatar
Default Aftermarket system question
i have a 2008 colbalt lt without onstar..i purchased a colbat mono amp and a 10 in boston acustics sub for it ad was wondering could i just hard wire it to the back speakers like i did in my blazer or do i need something special for it
Old Oct 6, 2009 | 7:26 AM
UpOnOne69's Avatar
You can pick up an fm modulater from almost any audio shop. Splice it into you rear left and right speakers, it has RCA jacks that u run to your amp. It should cost you no more than $25. Then hook up your ground and power, run your remote wire to any fuse that provides power when your ignition is on.
Old Oct 6, 2009 | 12:42 PM
IndyUchiha's Avatar
thankyou
Old Oct 6, 2009 | 6:43 PM
shawnvw's Avatar
Banned
correction...you need a line level converter....not an fm modulator
Old Oct 9, 2009 | 6:27 AM
mudmaniac's Avatar
Ride of the Month
May 2009
Correct, unless the amp you have has both RCA and line level inputs, if it does you may not even need the remote hooked up using the line level inputs.
Old Oct 10, 2009 | 10:55 AM
IndyUchiha's Avatar
thanx i didnt need the remote wire hooked up that was surprising...
BuyBigSUV
Jan 22, 2014 11:20 AM
surfandride
Jan 16, 2011 10:05 PM
davemdg
Avalanche
Apr 30, 2009 3:56 PM
