Cobalt This sporty compact was faced with the difficult job of replacing the popular Cavalier, but whether the base model, or the supercharged SS is chosen, is has made for a great replacement.
Platform: Delta
Also Check out CobaltSS.net
Chevy Cobalt SS 2007 service traction light
Old Apr 28, 2021 | 1:13 PM
Virginia Hardy's Avatar
Default Chevy Cobalt SS 2007 service traction light
I had a mechanic change out my front bearing hubs because they were making noise. All was fine & dandy. Winter came on and on a cold damp day "service traction" would pop up when you go to start the car sometimes. I bought a scanner tool and got a C0040 code to pop up. That was front right speed sensor fail, connection loose, or grounded. As soon as you would start, the light would go out. Get 4 dings, then ABS light would go out after pulling forward 50 feet. I cleaned the connectors and haven't had any problems until I pressure washed the car. It through the service traction light on again, but it was different. Before I would get traction off, then service traction. I cleaned it off again and replaced the wire loom & siliconed the hub entrance way. That fixed it finally I thought. Now it only comes on when close to welders, gate openers, and driving by the hospital imaging building in the day. Could I have a ground fault on the negative wire going to the wheel sensor? That would cause it not to shield correctly and make it act up from noise.
bradleyesco22
Jan 28, 2020 5:00 PM
redrotor
Cobalt
Aug 29, 2019 8:38 PM
kingjayrock360
Aug 10, 2017 11:00 PM
walterskevin
Cobalt
Aug 3, 2017 1:16 PM
DoubleG
May 5, 2010 9:00 AM
