Cobalt This sporty compact was faced with the difficult job of replacing the popular Cavalier, but whether the base model, or the supercharged SS is chosen, is has made for a great replacement.
Platform: Delta
Also Check out CobaltSS.net
Code 11 on dash?
Old Nov 2, 2019 | 2:02 PM
Cristelle's Avatar
Default Code 11 on dash?
Can anyone tell me why code 11 appeared on my dash when I shut car off?
Old Nov 2, 2019 | 3:11 PM
oilcanhenry's Avatar
No idea. OBD II codes are 3 to 4 numbers.PO 0011 would be a VVT code.but it would not be on your dash. It is read with a code scanner, which you might have done, to see if anything is wrong.
BTW, have you replaced your ignition switch? Cobalt's have a tendency to shut off if it is touched while driving. The dealership HAS TO DO IT FOR FREE too. Its a safety issue and people died due to this issue leading to lawsuits. Everything goes dead including your power steering and it can cause a crash. Chevrolet will gladly put a new improved ignition switch in your Cobalt. If the dealership says otherwise, contact the NTHSA.
fjwewers
Mar 29, 2015 12:02 PM
bbish0p
Nov 17, 2009 7:54 PM
treadhead
Jun 19, 2009 11:43 PM
88marine
Mar 14, 2009 1:08 AM
buijon
Dec 14, 2006 2:11 PM
