Cobalt This sporty compact was faced with the difficult job of replacing the popular Cavalier, but whether the base model, or the supercharged SS is chosen, is has made for a great replacement.
Platform: Delta
Also Check out CobaltSS.net
Help car won't started
Old Apr 7, 2018 | 4:13 PM
Tommy1969's Avatar
Default Help car won't started
Hi there, new to the forum. I have a 2006 Cobalt with the 2.2l.. Last time I drove the car it was making a loud knocking noise so I' parked it. It has been about 6 months since it was driven last so the battery was dead. I charged it up but now when i try to start the car it fires off but doesn't start up. I get the message Eng Pwr Reduced and the car will not start. I was going to sell it to a neighbor but can't start it. What would be the first thing to start with.. I did pul get code P0601. Any help in getting this thing started would be great. Thanks in advance.
Old Apr 22, 2018 | 8:05 PM
Tommy1969's Avatar
Default Answers
anyone got any ideas.
Old Apr 23, 2018 | 12:15 AM
if the codes are stored (not active), clear them out and try to restart the car. when a battery slowly dies....modules lose communication and this sets codes. If any codes reset, post them here.
did you swap out or replace any modules?
Old Jun 11, 2018 | 5:11 PM
tim_cleaveley's Avatar
This code is common when the PCM isn’t getting a full 12 volts.
it could possible be a bad ground as well.
The worst case case is a bad PCM or a PCM that needs reflashed.
