Cobalt This sporty compact was faced with the difficult job of replacing the popular Cavalier, but whether the base model, or the supercharged SS is chosen, is has made for a great replacement.
Platform: Delta
Also Check out CobaltSS.net
Intermittent A/C problem
Old Jun 24, 2015 | 6:51 PM
averymechanix's Avatar
Default Intermittent A/C problem
I read through some of the other posts on this issue and it seems like mine may be a little different.
My A/C works great when it works, not low on freon (checked low side only as I no longer have manifold gauges ), does not cycle on and off, my coolant temp and ambient temp seem to be reading fine, however still the A/C sometimes just doesn't work. Clutch doesn't even try to engage when it isn't working and locks right up when it is working.
My thoughts are A/C relay, or pressure switch? Anything else I could be missing?
P.S. I don't think this is related but my cruise control works only about 75% of the time, the key fob works about 95% of the time, the fob controlled trunk button does not work, my front speakers do not work, and the passenger airbag sensor thing is broken.
Old Jun 24, 2015 | 10:34 PM
Alright so quick update. Removed the relay and ran a jumper wire. This made the clutch engage and the A/C work. Tried replacing the relay and still nothing.
Old Jun 25, 2015 | 2:20 PM
KChevy75's Avatar
Any problems with your temperature display not showing a reading?
It could be a bad coolant temperature sensor.
Old Jun 25, 2015 | 5:54 PM
Coolant and ambient temp work fine always.
Old Jul 12, 2015 | 8:00 PM
hipyhipe's Avatar
It could be 1 faulty relay switch, 2 blown fuse and last is worn out clutch compressor.
Old Jul 19, 2015 | 10:17 PM
Long_Range's Avatar
My 2008 5 speed has intermittent problems with the AC too. When my temperature gage does not give a temperature readout, my AC does not blow cold. When the temperature gauge works, AC blows nice and cold. Defrost same symptoms as AC.
It coded P0128, and so I replaced the temp sending unit, then the thermostat. Still workes sometimes, sometimes not.
Now my tachometer sometimes quits working and the engine misfires, stalled completely once.
Any ideas? I have had my ignition changed out under the recall a few months back.
suthman100
Feb 1, 2007 7:25 PM
Wack
Oct 25, 2006 12:08 AM
golfhound888
Oct 4, 2006 5:37 PM
ffarv
Apr 9, 2006 1:52 PM
