Cobalt This sporty compact was faced with the difficult job of replacing the popular Cavalier, but whether the base model, or the supercharged SS is chosen, is has made for a great replacement.
Platform: Delta
Also Check out CobaltSS.net
My Gauges started jumping.
Old Aug 7, 2017 | 4:51 PM
Chas4957's Avatar
Default My Gauges started jumping.
I was driving and all at once my tach dropped to zero fuel gauge dropped to empty I got a low fuel warning then power steering warning the security lock was displayed, check engine light was on, trans started shifting real hard, any ideas please
Old Nov 20, 2017 | 9:19 AM
eastsidecarguy's Avatar
Default mine too
Did you ever find a solution to this. I had similar situation with my 06 cobalt. After I had changed the transmission fluid and filter(not sure if a connection between that and problem)
I took the car on a 25 mile errand. When I got on the highway, the security light came on, got power steering message(although power steering still worked), speedometer and tach needles started waivering back and forth, and transmission acted up. Concerned that if I shut it off it might not start I turned around and went home. In the safety of my garage I shut it off and when I restarted it everything seemed to be back to normal. Have seen other poasts about similar problem, but haven't seen any solution to it.
Old Nov 21, 2017 | 7:41 AM
speedOhead's Avatar
the instrument cluster on the 06 colbat does not control the trans. kinda sounds like you were losing power. double check the charging system. if the cluster does lose power the gauges will act crazy
Old Jun 11, 2018 | 5:22 PM
tim_cleaveley's Avatar
It’s a common problem in the internals of the body control module. (BCM)
next time this happenes give the BCM a smack or kick, if it straightens right out that’s the culprit.
The BCM is located under the radio, passenger side. It is essentially the passenger side fuse box.
