Cobalt This sporty compact was faced with the difficult job of replacing the popular Cavalier, but whether the base model, or the supercharged SS is chosen, is has made for a great replacement.
Platform: Delta
Also Check out CobaltSS.net
switching radios need help
Old Nov 15, 2007 | 9:04 PM
aem121401's Avatar
Default switching radios need help
I hope someone can help me i have a 2006 chevy cobalt ls with factory cd player in it and i want to put my sony cd player amp box etc but i have know i dea how to get the factory out ineed help with that also if someone can let me know where i can get the in dash kit that i need to put the sony in all help in this matter will be appreciated thanks allen
Old Nov 15, 2007 | 10:29 PM
Red07SSNA's Avatar
Default RE: switching radios need help
Please note that your radio is tied into the body control module (BCM) through a GMLAN serial data link. It is not a simple matter toadd accessories or swap outradios as you may affect other systems. Your best bet is to talk to the service manager/department at your dealership for more information about this. I've read some horror stories about owners that tried. I read through the 2006 Cobalt service manual to see if I could give you some help -- there is no information on adding aftermarket accessories.
Old Nov 15, 2007 | 10:40 PM
engine2's Avatar
ORIGINAL: Red07SSNA
I agree - Get someone who knows what they are doing.
Old Nov 16, 2007 | 9:05 AM
Red07SSNA's Avatar
Some good information for you oncobaltss.net (good site for Cobalt owners). Read the entirethread -- you might find the answers in it.
http://www.cobaltss.net/forums/showthread.php?t=21371
Good Luck!
Old Nov 16, 2007 | 8:24 PM
aem121401's Avatar
Thanks for the info i will check it out ill get with the dealership i didnt think it be that difficult being that its just a basic model car nothing fancy thanks all
Old Feb 17, 2008 | 7:46 PM
charlie pachanga's Avatar
Use the correct lan bus interface, a few companies make them I mainly use metra's pieces, you should not have any issues as long as you use the correct interface.
Old Feb 17, 2008 | 8:42 PM
shawnvw's Avatar
Banned
exactly as charlie said...use the right parts and you won't have a problem. Plan on spending a few bucks for it.
The radio comes out by taking a plastic pry bar, popping the upper right corner of the knee bolster out, prying out the small trim piece to the left of the radio. Open the glove box, and remove the trim from about the radio. Then pry up the trim around the radio. there should be 4 7mm bolts holding the radio in
taharqa23
May 11, 2011 8:58 PM
MattHamby
Apr 2, 2009 9:53 AM
swoosh1977
Sep 29, 2008 5:36 PM
08dmaxman
Jan 9, 2008 7:09 AM
