Cobalt This sporty compact was faced with the difficult job of replacing the popular Cavalier, but whether the base model, or the supercharged SS is chosen, is has made for a great replacement.
Platform: Delta
Also Check out CobaltSS.net
why 180 degree thermostat for 2003 saturn vue w/2.2l w/5 speed
Old Mar 6, 2018 | 8:19 PM
grumpyump's Avatar
Newly Registered
Default why 180 degree thermostat for 2003 saturn vue w/2.2l w/5 speed
2003 saturn vue w/2.2l and 5 speed . service engine light OBD ll code said thermostat not opening fully. replaced thermostat ( Dumb idea idea for me) from oreillys but learned after installing it was 195 degree. chevrolet says to use 180 degree. will higher temp harm engine
Old Mar 7, 2018 | 7:07 AM
kevinkpk's Avatar
No. I never run 195, but it will be fine. If you are in a cold climate the higher temp tstat will keep your heat higher.
