Chevrolet Colorado
Platform: GMT 350, GMT 31XX
2006 colorado
Old Aug 10, 2013 | 1:27 PM
motorman's Avatar
Default 2006 colorado
my grandson just bought 2006 WT with 4 cylinder,2 WD and a 5 speed manual trans. it has 49,500 miles and is super clean. what should he look out for ??? THANKS
Old Jul 15, 2014 | 6:53 PM
rickss396's Avatar
Default 06 colorado
Hello, Some issues I have had with my 06, 2.8 4cyl. which just turned over 100K miles. They are notorious for blower relay switch trouble. This is an easy fix though with a replacement for @ 15 bucks. But until it is replaced you will only have high fan. They are also known to have Purge valve solenoid trouble and or the purge canister valve. Both will cause a check engine light. You must read the code to figure out which it is. I hope this helps some. Mine is a 4X4 and is horribly under powered also.
food111
Colorado
Aug 2, 2014 8:05 AM
tjfab
Colorado
Nov 10, 2013 12:35 PM
2006colorado
Colorado
Jun 6, 2010 11:07 PM
jaymoore74
Colorado
Dec 22, 2006 7:50 PM
motorush
Apr 6, 2005 4:31 PM
