Chevrolet Colorado
Platform: GMT 350, GMT 31XX
2015 Colorado transmission bucks
Old Jan 27, 2022 | 7:47 AM
mark249's Avatar
Default 2015 Colorado transmission bucks
I've been reading online where Chevy discontinued making the Colorado in 2012 along with a lot of bad reviews on transmission problems and began production again in 2015 with a new designed transmission to hopefully correct the problems, guess the new design didn't help much. My 2015 Colorado is beginning to buck when I accelerate from low speed to high speed, or going up a hill, and in windy weather facing the vehicle, sometimes a loud bang with the bucking. Chevy dealer not sure what causes this problem and wants to tear into the transmission to see what may be causing this, said it may be a few worn parts, bad torque converter, or maybe needs a new transmission, could be hundreds or could cost me thousands to fix. You would think after all the bad transmission reviews they would have a recall to fix this problem or come up with a better designed transmission. Has anyone had this problem with their Colorado?
2015 Chevy Colorado LT
102, 000 miles
4 wheel drive
3.6 engine
Old Jan 27, 2022 | 8:36 AM
hanky's Avatar
Before going after a POSSIBLE trans problem, are we sure the engine is not breaking down under load?
What kind of maintenance has been done to the engine in the last 3 months?
Old Jan 28, 2022 | 6:36 AM
mark249's Avatar
In the past few months my mechanic had to take off the engine plenum to put new spark plugs in, plus did an oil and filter change, that was it.
Old Jan 28, 2022 | 11:50 AM
Oldirongut's Avatar
Is this the transmission shudder due to improper trans fluid that contains water.?? a trans flush might help. see trusted dealler
Old Jan 28, 2022 | 3:58 PM
mark249's Avatar
I was just at my mechanics shop last week and had them check the transmission fluid, we drained some fluid out to see what it looked like, nice and clean, still reddish in color not milky, no burn smell, and no kind of metal shavings on the drain plug. Put back in new fluid to replace what we drained out, it was the correct fluid, I bought it right from the dealer. Not sure if the transmission filter may be dirty and not getting the correct fluid inside the transmission for it to shift properly, the truck does have 103, 000 miles on it, don't think the filter was ever changed or cleaned. Guess I'll have to make another appointment at the dealer and see if they have any new suggestions, all they tell me is leave the truck and they'll start taking the transmission apart and see if they can find the problem, $$$$$$
Old Nov 11, 2022 | 1:00 PM
john holmes's Avatar
Trans Shudder..........New Colorado 2022 3.500 miles Torque Convert ruined asfter 2 Mobil One flushes. Trans shot, There are NO simple fixes for this problem....... Dealer bought truck back, Glad to be rid of that Failed Transmision
Old Nov 12, 2022 | 11:51 AM
The proper fluid is Mobil One Blue (dealer should know that) I had 2 flushes, still failed that trans is Junk, Dealer bought back my new Colo. with 3,500 miles
mark249
Jan 26, 2022 8:13 AM
diefoooll
Colorado
Jul 30, 2015 10:02 PM
DSHACK13
Colorado
Mar 1, 2014 5:22 PM
steveo2155
Sep 28, 2013 11:45 AM
ZR2 future driver
Colorado
Feb 12, 2013 2:36 PM
