amp install to factory radio
RE: amp install to factory radio
sorry for the late replay, was out of country.....hope your still coming around the forums.
There are 2 ways you can do the amp install. Depending on the configuration of the amp, will tell you the easiest way to do it.
If the amp has a high level audio input, then the easiest way to install the amp, would be to run 2 sets of speaker leads to each door. 1 input, 1 output.
The other way would involve buying 2 line level converters and RCA's. This would be easiest at the radio. Install the line level converter into the speaker leads, then run RCA's to the amp, then run new speaker leads to each speaker
hpshooter
July 24th, 2013 11:27 PM
thehighclass
January 17th, 2011 9:50 AM
adamant
February 15th, 2009 8:49 AM
