Last edit by: IB Advertising
Browse all: Interior
- Chevrolet Silverado 1999-2006 GMT800 Why Doesn't Blower Motor Work
Step by step instructions for do-it-yourself repairs.
more heater/ac issues
anybody have an idea what's wrong with my heater/ac, it only works on 4(hi). When you turn it the lower settings (1-3) nothing comes out.
yeah had someone email on another forum. .
"Sounds like a bad blower motor resistor. The blower motor resistor uses multple resistors inside to vary the amount of voltage the blower motor gets. In the low speed, it cuts the volatage the most and also generates a high amount of heat, in med, it cuts the voltage a little less and in high, the resistor is basically bypassed and the motor gets whatever the system/battery voltage is. The resistor is usually mounted near the fan in the fan housing. It is usually held in with two screws and has 4 or more wires on it, depending on the amount of speeds. It is in the housing as it uses air from the fan to keep it from overheating."
So I bought one and haven't put it in yet
Intermittent Heater Blower
I guess I could update mine too. I found another thread on the board that mentioned that it could be something as simple as the electrical connection. Took 20 seconds to troubleshoot after that. With the car running and fan switch on either 1, 2, or 3 I reached under the dash on the passenger side and jiggled the wire connector and the fan came on immediately.
I haven't actually fixed it yet but it should be relatively painless and quick when I do.
Mine has the same problem, i can only have it on speed 2 and if i switch it to another speed it would turn off. some friend found that a connecter under the dashboard in the passenger side underneeth by the floor there is a connecter that is for the ac controls and he found out the the connection was bad so thats why it turns off when i switch it to another speed. I havent bought it yet because ive havent had the money for it and i dont know how much it cost. Ill update this post when i buy it and install it. Hopefully it works and it can help the rest of the people.
Ditto
Chevrolet Forum News
May 31st, 2013 12:38 PM
Tnbrock
March 29th, 2013 11:13 AM
07Silveradooo
July 30th, 2011 4:21 AM
