Very strange turn signal/brake issue...
I have a 2006 Isuzu i-280. It's still under warranty, but I was hoping to get an idea of what the issue is before I take it in.
Very recently, my truck started acting goofy when I apply the brakes. I will elaborate.
When I press the brake pedal, my left turn signal arrow on the dash lights up halfway. The turn signal clicks once while the brake pedal is depressed. When I take my foot off the brake, the left arrow goes out and the turn signal clicking noiseclicks off.
When I go to turn on my right turn signal with the brake depressed, the turn signal clicker does not make the clicking noise.
When I go to turn on my left turn signal with the brake depressed, the turn signal flashes rapidly (like when a bulb is burnt out). The clicker does work though.
However, when I do NOT have the brake pedal depressed, both left and right turn signals operate normally.
This is an intermittent problem, although it is getting much worse. I do have a trailer hitch (installed by U-Haul) and I am not sure if this would affect anything. I have had the brake switch recall fixed already.
Any help is truly appreciated! Thanks!
RE: Very strange turn signal/brake issue...
Uhaul is infamous for messing things up, particularly shorting things to ground when they install hitches. You have a short to ground somewhere causing your symptoms.
fishingpro77
HHR
August 4th, 2016 12:44 AM
RomanGuzi
October 2nd, 2011 11:40 AM
