Corvette Since 1953, the All American Sports car, and with the new 2014 C7 model, no end is in sight.
2014 Corvette C7
Platform: Y-body
Latest Corvette C7 News here: CorvetteForum.com
1977 LT 350 Low Oil Pressure Troubleshooting
Old Jun 8, 2014 | 10:39 PM
1977LT350's Avatar
Default 1977 LT 350 Low Oil Pressure Troubleshooting
Hi,
My name is Patrick and I'm new to the forum. I did a search for threads that might help me but, didn't see much. I'm sure it's out there but, I'm having difficulty.
Just rebuilt a '77 LT 350 out of a 'Vette and put it in a Ford Rat Rod. Engine runs well with good oil pressure and everything when you first crank it up but, once it warms up oil pressure drops from around the 30PSI mark to all but zero. the engine is a fresh rebuild so, bearing clearances should still be good and I just replaced the oil pump today with a brand new high volume pump. Still has the same issue. The gauge I'm using is a Sun Pro mechanical model and the engine never makes a strange noise like it is starving for oil. I'm now outside my expertise and afraid to lock up this brand new build.
This is my first Chevrolet build and I haven't built much of anything in the last 15 years or so. Just thought I would talk to some guys with a little more experience.
Old Jun 9, 2014 | 10:30 AM
old dog's Avatar
if the oil pressure is good enough when you start it but they drop when it warms up ,i would look at bearing clearances especially the main's and cam bearings . check the crankshaft journal sizes also
Old Jun 9, 2014 | 11:09 PM
1977LT350's Avatar
Thanks, Old Dog. I was hoping to not have to pull the engine again but, I guess I'll just have to bite the bullet.
Old Jun 10, 2014 | 10:55 PM
sledge.impy's Avatar
I'm not that old school - but...
Are you sure the gauge is correct?
What happens when you give it gas? Does it go from 0 to xx ??? Or does it stay at 0?
Are you squirting oil up top?
Did you do or need to do an engine break in?
What weight oil are you running?
okay this is really ignorant question since I don't know and not about to google up years of engine building - is this a roller or flat tappet setup?
Old Jun 13, 2014 | 3:08 PM
1977LT350's Avatar
I wasn't sure the gauge was correct. When you hit the juice the pressure would climb slightly and then drop again. I didn't pull a valve cover yet but, I did hook up the oil pressure tester. It shows 18-22 PSI at idle even after warm. No break in yet. I just dropped it in a couple of weeks again the truck still isn't ready to drive. Castrol 10/40 in a flat setup.
Old Jun 14, 2014 | 8:28 PM
Is that oil flat tappet compatible?
List of Flat-Tappet Oils - Corvette Forum
What does your engine builder say, or did you build it yourself?
jaeger_bombs
Feb 10, 2016 8:27 PM
Eric Sherden
Sep 24, 2013 1:21 PM
not_a_car_dude
Sep 15, 2013 7:41 PM
MikeShirk
Dec 31, 2012 10:39 AM
Terry Odell
Jan 2, 2012 5:09 PM
