Corvette Since 1953, the All American Sports car, and with the new 2014 C7 model, no end is in sight.
2014 Corvette C7
Platform: Y-body
Latest Corvette C7 News here: CorvetteForum.com
427 issue
Old May 31, 2020 | 2:17 PM
Don Maw's Avatar
Default 427 issue
Have a 427 tri-power with solid lifters. As motor temp increases engine misses out and will die when let off accelerator. Has TIC ignition.Did compression check. Ok.
Have videos but can’t post here
any good ideas.
thanks
Old May 31, 2020 | 2:49 PM
kevinkpk's Avatar
any good ideas.
thanks
Need more info, what fuel system, when did this start, what changed since this issue?
Old May 31, 2020 | 7:02 PM
Don Maw's Avatar
it has 3-2barrel Holley carbs.
car sat 7 months and may have stale gas. Drove about 10 gal out refilled tank and added Seafoam. Maybe need a longer drive
thanks for note
Old May 31, 2020 | 7:39 PM
kevinkpk's Avatar
thanks for note
More about when this started with the 3 duces? It could be vapor lock or again, when did this start?
Old Jun 1, 2020 | 5:07 AM
Don Maw's Avatar
thanks for note
This issue just started several weeks ago. It was fine last fall. The center carb and fuel lines are not hot to the touch. Fuel is not percolating in carb
Tlvsdestiny
Jun 5, 2018 8:26 AM
Trollsmeesh
May 30, 2018 3:23 PM
abuadam
Mar 10, 2017 2:16 PM
draymond824
Oct 13, 2011 6:07 PM
frostmonkey74
Feb 1, 2010 6:16 PM
