Corvette Since 1953, the All American Sports car, and with the new 2014 C7 model, no end is in sight.
2014 Corvette C7
Platform: Y-body
Latest Corvette C7 News here: CorvetteForum.com
Big block oil pressure issues
Old Jun 29, 2012 | 5:31 PM
Sonerai2004's Avatar
Question Big block oil pressure issues
Hi, Im new to this forum and in need of some help with my corvette. I have a 69 with a 427 in it, I've had it for 32 years, but have not driven it much as I have had this problem since I've owned it. The oil pressure when started is around 40-45 psi, but as the engine temp. Goes up the oil pressure goes down, to zero at temp. 200 deg. range. I have replaced main, rod, cam bearings twice, had the crank cked. At a machine shop for trueness, plastic gauged mains and rods, .001-.0025" tried thicker oil 10-40' 20-50. 2 different oil pressure gauges, 2 different oil pumps with different pick-ups, currently has a mellings m77hv high volume pump, pick up is 3/8 to 1/2 inch from the bottom of the oil pan (7 qt.)
And still has the same issues, has anyone ever encountered this ? Any help would be greatly appreciated. Thanks
Old Jun 29, 2012 | 5:49 PM
kevinkpk's Avatar
I don't think anything that early had an oil cooler. Does the pressure vary at all at temp with rpm? Those clearances you state are very tight.
Old Jun 29, 2012 | 7:34 PM
Default Big block oil pressure issues
Yes, when I raise the engine speed when at temp. the oil pressure will go up, aprox 20 psi @ 2500 rpms
Old Jun 29, 2012 | 7:54 PM
kevinkpk's Avatar
I know I read two new guages, if you don't have any "noise" from the engine, place an independant oil pressure guage just to verify.
Old Jun 30, 2012 | 10:34 AM
Are you using an electric or mechanical oil pressure gauge?
Old Jun 30, 2012 | 9:18 PM
I'm using a mechanical oil guage, and one of the 2 gauges that have been connected was an external guage, still have the same results.
Old Jun 30, 2012 | 9:25 PM
kevinkpk's Avatar
So, you are not loosing oil, external or internal?
Old Jun 30, 2012 | 9:41 PM
No not loosing oil externally, and I haven't run the engine long enough to see if oil level goes down, but I have no signs of burning oil.
BoogerHog
Dec 25, 2016 11:32 PM
viborero23
Dec 5, 2009 8:03 PM
onecoldmini
Mar 4, 2009 8:13 PM
1636ProMOD
Aug 6, 2008 2:09 PM
