Corvette Since 1953, the All American Sports car, and with the new 2014 C7 model, no end is in sight.
2014 Corvette C7
Platform: Y-body
Latest Corvette C7 News here: CorvetteForum.com
Very low compression. Ahhh!
Old Oct 10, 2023 | 12:53 PM
Spinyay's Avatar
Default Very low compression. Ahhh!
My Mom gave me my Dad's 86 Corvette when he passed away this January. I am grateful for it. I also knew that it wouldn't run for a few months and sat over winter. When I started working on it. The engine was seized and it needed a starter. I replaced the starter with a high torque and managed to unseize the engine. The fuel system had quite a bit of water in it. I've completely emptied the tank of gas water. Plenty of spark with a spark plug tester. No fire. So, I did a compression test. Ahh!
Old Oct 10, 2023 | 2:52 PM
did you lube the pistons before breaking it loose? You may have damaged the rings (or even the cylinder walls).
Old Oct 10, 2023 | 4:09 PM
Rednucleus's Avatar
broken timing chain??
Old Oct 10, 2023 | 4:44 PM
Spinyay's Avatar
Yeah, I filled the cylinders with ATF and PB blaster. Soaked it for about a week before it broke loose. i agree, it may have ring and cylinder damage
Old Oct 10, 2023 | 4:46 PM
Spinyay's Avatar
Yeah, it's difficult to say what it is without tearing the engine apart. That may be my only option.
Old Oct 11, 2023 | 7:15 AM
Spinyay's Avatar
It may be out of time. Would that cause low compression?
Old Oct 11, 2023 | 1:27 PM
I'm no expert, but it would seem to me that the timing would have to be very severely off. So much that a valve opens on the compression stroke. Isn't that close to 180 deg?
Old Oct 11, 2023 | 2:49 PM
Rednucleus's Avatar
What if a timing belt/chain was busted??
Old Oct 11, 2023 | 7:25 PM
Spinyay's Avatar
Not sure what's wrong with it, unless I just start tearing it down. I guess I'll have to rebuild it. This will be my first time rebuilding an engine. So, since I have very little engine knowledge. I wonder how much HP I can get out of this 1986 Corvette L98 5.7L V8?
Any advice and experience knowledge would be very helpful. Thanks!
Old Oct 11, 2023 | 10:05 PM
I'm watching an engine rebuild video right now actually (just for fun, because I'm weird like that). It might help you.
