Chevrolet Cruze
Also Check out CruzeChat.com
2011 Chevy Cruze LS 6 Speed
Old Sep 19, 2022 | 8:08 PM
cosmicpeach's Avatar
Default 2011 Chevy Cruze LS 6 Speed
Hello,
Some background, I've been having some other power related issues such as the car shutting off when idling with the ac on but only with the specific scenario and the performance of the car didn't seem to suffer. However I'm not having issues with the car not wanting to start.
Symptoms:
  • Doesn't want to start. Sometimes the lights on the dash will come on, door will chime, radio will come on. Most recently everything is dead and car was jumped and everything came on.
  • Extremely slow to accelerate, have to turn off a/c.
  • Decreased gas mileage. Used to be 28.5-28.7, now is 25.5ish.
  • Service stabilitrack comes on while the radio and leds on the radio simultaneously turn off. This is brief, 20-30 seconds and it turns back on.
  • Exhaust leak, whining noise.
  • Engine codes: P0014, P0171, P0420
  • A/C causes car to shut off while idling. Whether in park or in neutral.
The battery is a month or two old, no reason for it to be the battery. That was the original thought. Oklahoma heat + battery=disaster but apparently not.
Any insight? I'm working on getting these things repaired but like many, life is difficult and I don't have a bunch of money to throw at this all at once. So I need some guidance. Any and all help is appreciated and I do have someone who will be doing the work for me.
Thank you.
Old Sep 19, 2022 | 10:15 PM
oilcanhenry's Avatar
You are having exhaust issues with your VVT engine. Likely a bad Catalytic Converter. You may also have EGR valve issues, even if it doesn't show up on your scan-tool. I'd check you ground wires and cables for corrosion or tightness.
irene91744
Cruze
10
Oct 9, 2022 4:27 AM
Kimmyboy
Cruze
Nov 7, 2021 8:28 PM
Jason Pearce
Jan 19, 2021 4:49 PM
Izzy_A
Nov 23, 2020 2:34 PM
Izzy_A
Cruze
Nov 23, 2020 1:59 PM
