Chevrolet Cruze
Also Check out CruzeChat.com
2013 chevy cruz long crank
Old Apr 4, 2019 | 1:00 PM
Zied Dorgham's Avatar
Default 2013 chevy cruz long crank
The engine wiring harness on my cruz was half burnt going to the ac conpressor so i changed it.
After that the car wont start. It cranks cranks for a good 15 sec then stops.
It will start after 30 min sitting but will shut off after 5 min.
I got the harness from chevy and plugged everything in correctly. Now i get dtc p0341 and p0365.
both connectors to the camshaft sensors are plugged in correctly. Car was working fine before the work so i dont think it s the sensors that went bad.
Old Apr 5, 2019 | 1:18 PM
Did you check the fuses?
https://www.obd-codes.com/p0365
"This P0365 code indicates that a problem was detected in the camshaft position sensor circuit. Since it says circuit, that means the problem could lie in any part of the circuit - the sensor itself, the wiring, or the PCM. Don't just replace the CPS (camshaft position sensor) and think that will definitely fix it."
