Chevrolet Cruze
Also Check out CruzeChat.com
Engine fan won’t shut off
Old Dec 21, 2017 | 1:50 PM
Ashlie's Avatar
Default Engine fan won’t shut off
I have a 2011 Chevy Cruz Eco and recently the engine light has come on and the fan won’t shut off. The temp never gets hot and it seems to run fine aside from the loud fan! I’m at 128,000 miles so I don’t think there’s any warranty I qualify for. Anyone have any suggestions to avoid a pricey dealership repair?
Old Dec 21, 2017 | 2:48 PM
kevinkpk's Avatar
Possibly the fan relay contacts are welded together. Unplug it. Turns off, replace the relay
Old Feb 1, 2018 | 4:21 PM
jmssimms75's Avatar
This is a common problem....i surmise that if you had the codes checked, you would get P0597/P0598--has everything to do with chevy switching to a thermal housing instead of a simple thermostat. If you look online for that code you will see a lot of chevy's are having problems with this. I'm currently having this problem and "patiently" waiting for some Chevy Rep to actually contact me. I have to pass a emissions test for my Chevy this month, but I can't pass while experiencing these codes.
Old Jun 13, 2018 | 10:18 PM
Andrew Fuentes Sr.'s Avatar
Default reply to fan on. Problem
check th trouble codes and see if they are P0597 or P0598. They both deal with the coolong fan sensor. It goes bad and need to be replaced. Dealer replacement part is half metal and half plastic, you can order a complete replacement from Rock Auto and it cost less than the original part. Also it is a complete metal on metal parts.
