Chevrolet Cruze
Also Check out CruzeChat.com
Fans running and burning smell
Old Apr 7, 2017 | 8:03 AM
Paul Wightman's Avatar
Default Fans running and burning smell
Hi,
My Chev Cruze occasionally has a burning smell when I open to door to get out and the fans run for longer than I would expect. What could this be? Also, we got the car from a dealer and it had to go back as hot air was coming out from only one side of the car fans inside, maybe it is related.
Old Apr 7, 2017 | 11:53 PM
Is the car overheating? Are you getting a check engine light?
Old Feb 1, 2018 | 4:26 PM
jmssimms75's Avatar
This is a common problem....i surmise that if you had the codes checked, you would get P0597/P0598--has everything to do with chevy switching to a thermal housing instead of a simple thermostat. If you look online for that code you will see a lot of chevy's are having problems with this. I'm currently having this problem and "patiently" waiting for some Chevy Rep to actually contact me. I have to pass a emissions test for my Chevy this month, but I can't pass while experiencing these codes.
