Chevrolet Cruze
Also Check out CruzeChat.com
Installed OEM fog lights now engine wont start
Old Feb 28, 2021 | 12:38 PM
Day Michelle's Avatar
Default Installed OEM fog lights now engine wont start
Please, has anyone else had this happen? Where should I look?
Old Feb 28, 2021 | 1:06 PM
hanky's Avatar
Without actually checking ,physically ,your installation work, You might consider disconnecting any wring you made to your vehicle. I suggest this because we have no idea where you tapped into for power or anything else.
If everything was fine before your addition, there is a good possibility you tapped into someplace where you shouldn't have..
Not knowing more info, you might also check all the fuses. Sometimes a wrong connection could cause a fuse to open.
Day Michelle
Cruze
Mar 1, 2021 11:14 AM
Blkngold523
Sep 21, 2011 7:02 PM
mudebrock
Jul 7, 2011 10:28 PM
country_09
Mar 8, 2010 6:11 PM
leebo24
Apr 3, 2007 9:39 PM
