Chevrolet Cruze
Also Check out CruzeChat.com
Issues with zzp front brake kit
Old Mar 24, 2025 | 9:28 AM
Red66's Avatar
Default Issues with zzp front brake kit
Wondering if anyone has had issues after installing the 12" Front Brake Kit from zzp. Installed these on our 14 cruze and after putting 3000 mi in the first week they failed on us. One of the caliper bolts did Come loose but the main issue is the rotors. The don't sit flush on the hub and instead put the brake force on the stud and lug nuts. Because of this the mechanics wouldn't work on it without doing another complete front brake job.
Zzp rotor
Zzp rotor
Zzp rotor
Zzp rotor
Oem
Oem
Oem
Oem
Old Mar 24, 2025 | 9:46 AM
Rednucleus's Avatar
Did these rotors look identical to the originals? Maybe wrong parts??
Old Mar 24, 2025 | 9:53 AM
Red66's Avatar
rotors were supposed to be bigger and better than original so they dont looke the same besides stud spacing and zzp is persistent on that they sent right parts and they function fine with this flawed design.
nickj1200
Nov 15, 2023 6:06 PM
BAMADOG101
May 7, 2022 11:48 AM
