Chevrolet Cruze
Also Check out CruzeChat.com
Locating VSS (Speed Pulse)
Old Nov 19, 2010 | 8:44 AM
Kevin Archibald's Avatar
Default Locating VSS (Speed Pulse)
We have a new Cruze LS 2.0 Diesel. Need to fit a taximeter. Does anyone know where to locate the VSS wire. Have tried same place as EPICA, but no joy.
Old Nov 19, 2010 | 10:10 AM
EvansBlue's Avatar
The company that makes the meter may have a wiring harness that you can order.
Old Nov 10, 2013 | 9:09 AM
epicauk's Avatar
Default Meter
Dont know where the OP is but ive always simply had meters installed, and we have to have the tariff set to our councils anyway
Old Jan 23, 2014 | 8:03 PM
atikovi's Avatar
As far as I know the speed sensor at least on the automatic is internal to the transmission. And is this day and age, why don't you have GPS based taxi meter?
Old Jan 24, 2014 | 3:32 AM
epicauk's Avatar
Firstly, anyone can FIT a meter with the right feed, very few can set the tariffs, councils like to see a certificate (and bill) from an installer
as for a GPS meter, they simply arent accurate or reliable enough, they lose satellites in bad weather or under tunnels, and also, they use the satellites that guided cruise missiles and they often landed away from the targets...
I was quoted £250 for a new meter supplied and fitted or £300 if it needed a canbus connector
jsicard
Feb 9, 2009 9:38 PM
rgw1977
Jun 18, 2008 10:40 PM
Aanidaani
Jan 21, 2008 11:32 PM
demarpaint
Mar 27, 2007 9:18 AM
RWhiddon
Sep 7, 2006 1:32 AM
