Chevrolet Cruze
Also Check out CruzeChat.com
Oil cooler gasket number?
Old Jun 19, 2023 | 6:08 AM
fancyshirt's Avatar
Default Oil cooler gasket number?
Got a oil cooler gasket leak putting oil in my coolant. There are two different gasket numbers and I can't find any information if one of them is a fix for the common problem. The numbers are #25199750 and #55354071. Any help would be greatly appreciated.
Old Jun 19, 2023 | 8:34 AM
oilcanhenry's Avatar
What year and model do you have? Has it got a turbo? Don't run it with coolant in the oil. It will destroy your engine bearings.
Old Jun 19, 2023 | 9:24 AM
fancyshirt's Avatar
It's a 2013 1.8L LS. I don't think it has the turbo but I'm not 100%. I don't have coolant in the oil. It's the opposite, oil in the coolant reservoir. I can clearly see the oil around the oil cooler so I'm pretty sure it's that. I was going to replace it myself but I don't want to replace it with the same faulty gasket if I don't have to.
Old Jun 19, 2023 | 1:31 PM
Rock Auto Parts has the coolant gasket down at #24445723
Here is the link:
https://www.rockauto.com/en/moreinfo...sn=569&jsn=569
Dimension Crosser
Jan 27, 2022 9:00 PM
camotruck55
10
Jun 3, 2015 9:12 AM
darailf
Jan 24, 2011 8:47 AM
98vortec
Dec 21, 2010 5:58 PM
98greenventure
Jul 27, 2007 10:28 PM
