Engine Building & Overhauling All you ever wanted to know about building and rebuilding engines in here! Remember to post your model-specific questions in the correct section.
Camshaft numbers???
Old September 15th, 2013, 7:52 AM
903waterboy's Avatar
Default Camshaft numbers???
Bought this SBC that was partially completed. After breaking down to bare block, I have located all the info........ except the camshaft. Hydraulic / flat tappet. In front of the second bearing journal is cast # C18. Behind this second journal is cast #4. In front of fourth journal is CWC. Behind fourth journal is # 1529. Stamped on rear end of camshaft is F8.
The camshaft and lifters appear to be in good condition, no signs of cupping on lifters. Just putting together an engine for street use only, no racing.
Just trying to find out lift and duration. Any help would be appreciated. Thanks,
Old October 14th, 2013, 8:58 AM
randyshaw81's Avatar
If there is any mystery about a cam you always replace it. Chances are its stock and you could use a little more lift and a little more duration.
runge_24
June 7th, 2007 1:15 PM
gmycyk191
April 12th, 2007 4:14 PM
Nicklatech
March 4th, 2007 6:50 PM
86Caprice
November 5th, 2006 8:05 PM
viking88
April 2nd, 2006 7:48 AM
Quick Reply: Camshaft numbers???
