Engine Building & Overhauling All you ever wanted to know about building and rebuilding engines in here! Remember to post your model-specific questions in the correct section.
Engine noise identification help ?
Old May 2nd, 2018, 2:00 PM
DeltaRat's Avatar
Question Engine noise identification help ?
Hey guys, new to this site wondering if anyone can help identify this noise in my Chevy 2003 350 small block in my boat.
my boat overheated due to a stuck thermostat and the valves mushroomed on me.
I have already done the following but still have this noise.
- Replaced the thermostat (which was stuck closed)
- Removed Heads, had heads machined and stainless valves installed.
- Replaced Timing chain set with original GM parts
- Installed new plugs
- Drained and re-filled the oil.
Any help would be appreciated.
Old May 2nd, 2018, 3:05 PM
kevinkpk's Avatar
If it's upper engine, I'd say lifter or rocker arm
