Engine Rebuild Manual
So I have a Vortec 5.7 from a 99 Tahoe, Casting Number: 10243880 (1995-00 350 Gen.I crate motors and "ZZ4", roller cam, one piece rear seal). I guess this is a Gen III Chevy SB motor?
I was told it needs new piston rings but other than that the engine is in great shape... I am mechanically inclined but have not done much engine work. I'm looking at doing this work in my garage and essentially using this as a learning project for me. I'm curious as to if there are any good "How To..." manuals on how to go about this whole process.
I have an old Chiltons manual for my 77 Suburban which explains the process, but as I am going through this engine I'd like to check everything and make sure it meets spec for this motor. Do you think I should use the Chiltons manual to guide me through the process and find the necessary specs online for this engine? Or is there a manual that covers the dis disassembly and specs for this particular motor?
captain177
Silverado & Fullsize Pick-ups
April 8th, 2021 1:34 AM
lifelight
Sonic (Aveo)
June 1st, 2015 3:52 PM
ep1nephr1ne
September 7th, 2011 6:19 PM
car5car
February 17th, 2010 4:09 PM
