Equinox This SUV offers a smaller, sportier stance than the Trailblazer, all without compromising the SUV abilities.
Chevrolet Equinox
Platform: Theta
08 Equinox Idle/Surge Issues
Old May 16th, 2023, 1:10 PM
TNMTNTOP's Avatar
Default 08 Equinox Idle/Surge Issues
Have a 08 Equinox that is idling rough. The rpms will be around 800 drop to anywhere from 200 to 400. Then surge.
I have been addressing computer errors as they arise. Replaced MAP sensor, MAF sensor, EGR valve and tube, vapor purge canister, O2 sensor, the negative battery terminal that was loose, on top of numerous shop repairs. Nothing has made it better or worse.
I did take a halo box to monitor the voltage on the battery. When not running the battery is at 12.6. When running it starts around 14.6. Then when the rpms drop the battery drops to just below 13 and gores back up to 14.6 when the rpms surge. So I can’t help but think it’s an electrical issue. Any suggestions???
Old May 16th, 2023, 9:40 PM
ruley73's Avatar
What codes are you getting? Which engine - 3.4L or 3.6L?
Old June 19th, 2023, 3:45 PM
TNMTNTOP's Avatar
Right now I don’t have any codes. The latest code was something about idling low. It’s the 3.4.
Old June 21st, 2023, 1:22 PM
TNMTNTOP's Avatar
So one of the causes could be the Evap which I haven’t fully replaced. Can anyone tell me how to properly remove these vacuum lines. I’m going to pull a part for replacements. And is the second picture the actual canister?
Old June 21st, 2023, 7:35 PM
-what are the fuel trim readings at idle and at 2500 rpm...this data can be used to diagnose a vacuum leak.
-have you ever cleaned the throttle body
Old June 21st, 2023, 7:38 PM
the pic is to close. the lines don't come apart;.they are molded. What is the globby mess in the top pic
Jeff Anderson
Equinox
February 7th, 2021 11:11 PM
msw3113
Equinox
November 30th, 2020 7:23 PM
mncmopars
Equinox
March 25th, 2015 10:20 AM
DBG53
November 3rd, 2012 12:08 PM
armyspader
Equinox
January 25th, 2010 2:16 AM
Quick Reply: 08 Equinox Idle/Surge Issues
