Equinox This SUV offers a smaller, sportier stance than the Trailblazer, all without compromising the SUV abilities.
Chevrolet Equinox
Platform: Theta
2005 Equinox Hvac not working
Old August 9th, 2012, 10:57 AM
lee7of7's Avatar
Default 2005 Equinox Hvac not working
The Hvac stopped working on a recent trip. It has restarted a couple of times for a short period before stopping again. Mechanic checked and there is no power to unit. Fuses good. blower works when he gives it power. Nothing appears burnt out. No A/C is one thing no heater/defrost is another in Wisconsin. Any ideas?
Old August 9th, 2012, 11:10 AM
With fuses being good and no power to unit means it is either a problem with the switch or the wire to the switch or the wire from switch to unit. Check all connections and look at the wires closely for any possible problems.
Old August 9th, 2012, 10:44 PM
ruley73's Avatar
Just to clarify, is it just the HVAC blower motor that is working intermittently?
Unfortunately, even hooking it up directly to the battery doesn't rule out a bad blower motor. The next time it quits, try to give it a tap/kick and see if it starts up again. If it starts up again, the blower motor probably has a bad spot in it which is usually how they strat to fail. Eventually they get to a point where they won't work at all.
The power wire (red w/white stripe) at the plug going to the blower motor should be hot at all times. If not, then you have a bad connection somewhere or a bad fuse (HVAC BLOWER 40A - located in the fuse block under the hood).
Check the resistance between the purple wire at the blower motor plug and chassis/ground. You should have zero resistance with the ignition in the RUN position and the blower switch at the highest setting. If not, then remove and inspect the plug going to the HVAC control panel. Test the resistance of the ground wire (pin 12 - black w/white stripe) to chassis/ground. You should see a zero resistance reading here. If not, then you have a bad ground connection at the other end of this wire. You could simply cut this wire and connect it to another good grounding point or you could try to find where this wire currently goes to and clean the connection.
Here's a link to a wiring diagram that you should find useful.
2005-2006_Chevrolet_Equinox_HVAC_Circuit.pdf
Old October 25th, 2012, 11:02 PM
UpstateNY Bill's Avatar
There is a known defect in the wiring harness connector at the drivers side kick panel. Too much current going through the wire burns up the pin for the blower in that connector. If sitting in the drivers seat, just sideways kick the inside of the car next to your left foot and your ac blower may start working again. That is where the connector is. I spliced in a wire to bypass that one pin of the connector and haven't had a problem since.
Google "Equinox connector C200" and you will find the info you are looking for. Good luck.
Old December 4th, 2012, 11:27 AM
donee's Avatar
Hi I'm Donee happy to be here, I came here just to ask if you have any idea about Hvac Los Angeles?
Old January 19th, 2013, 11:45 AM
ronlandrette's Avatar
Default c200 equinox plug heater repair
pix attached of c200 burnt pin drivers kick panel,and repair of same
red and white wire , there are a few,if i banged the plug heater motor would start...thanks for the info guys---figured pix would help
Attached Thumbnails 2005 Equinox Hvac not working-burntpin.jpg   2005 Equinox Hvac not working-fixed.jpg   2005 Equinox Hvac not working-fixed2.jpg
Old January 21st, 2014, 11:11 AM
CHandy's Avatar
Default C200 repair/replacement
Does anyone know how to replace/repair/bypass the C200 connector?
Old April 13th, 2017, 8:45 AM
Bill Azana's Avatar
You know your stuff. I have exact same problem and you have saved me many hours of troubleshooting.
Thank you
Old April 14th, 2017, 8:58 PM
Sorry I haven't checked in here lately. I no longer have that Equinox, but I'm glad I could help.
The pictures above by ronlandrette show the same repair that I did.
Old September 11th, 2017, 11:22 AM
Melissa Aspinall's Avatar
Default No control over temp in HVAC system
Recently the AC stopped blowing cold. Now that it has cooled down the hot air is blowing cold. The air blows accordingly to what it's set at, but the temp is the same no matter the setting. My dad seems to think the switch for the shutter door is bad. Does this sound right? And does anyone know the easiest way to get to it?
Quick Reply: 2005 Equinox Hvac not working
